WTB NH USA -- 10,000 uF 63V capacitors -- Amplifier case -- OR can I just swap them with the caps in this pic?
Wanted to buy
I'm not sure I will ever complete my LM3886 amp kit because my case is too small or my transformer is too big.
I also have a Brian GT LM3785 kit.
I can run the LM3875 or LM3886 off of a Meanwell power supply I have.
But then it won't be "audiophile", no?
So maybe I won't need the rectifier and 50v caps.
Should I use these 50v caps to replace the 63v caps?
The 50v caps seem to be about double the volume of the 63v caps.
Or any one want to sell me some 10,000 uF 63v caps?
Seeing as the Meanwell's a regulated supply it might well sound better. But you do have to watch the common-mode noise - use a balanced input to the LM3886 to mitigate its effects. Or transformer isolate the input.
Learned a little about caps.
Nicest case I've seen:
AMPower from Australia:
https://liquidaudio.com.au/lm3886-gainclone-chip-amp-project-build/
Which caps are "best" for the application?:
https://www.digikey.com/en/products/detail/united-chemi-con/ESMH800VNN103MA50T/4002936
Or any one have any they want to sell?
Direct
ESMH800VNN103MA50U
Chemi-Con
In Stock: 105
Unit Price: $4.73000
Datasheet
Parametric Equivalent
ESMH800VSN103MA50S
Chemi-Con
In Stock: 0
Unit Price: $4.81000
Datasheet
Direct
380LX103M080A052
Cornell Dubilier Knowles
In Stock: 644
Unit Price: $11.05000
Datasheet
Direct
SLPX103M080H9P3
In Stock: 0
Unit Price: $5.00000
Datasheet
Upgrade
LLS1K103MELC
Nichicon
In Stock: 705
Unit Price: $8.60000
Datasheet
