This is my first post here...
I want to add a headphone jack to a vacuum tube pre-Amp I'm building. Nothing fancy, but low distortion, I'll design the PCB to fit my chassis space, so a schematic would be cool too. How is LM380, LM386, LM1875, TDA7265, etc...? What stereo chip Amp has low THD and a simple circuit that will fit on a 64x64 mm PCB (sans power supply) and makes a fine easy headphone amp? Driving phones is easy so power is not an issue, I can do L Pad attenuation and matching of the phones to an 8 ohm chip Amp.
I just have no experience with chip amps at all, so hoping for some guidance to fast-path a foolproof headphone jack here, looking for a good chip for this application. I was at the headphone Amp forum, but decided I don't want to spend the time on somebody's discreet Amp design which may need troubleshooting. So I thought a chip Amp would be better here, more turn-key.
Thanks!
Thanks!
You can try TDA2822M or Similar chip. Another good option is multiple NE5532 in parallel (Douglas self 5532 amp) but your PCB size isn't enough for that.
The OPA1622 is intended for that exact purpose. It's hard to solder by hand but the evaluation kit for it is quite affordable. I'd add a buffer before the EVM, though, as it has pretty low input impedance. That's what I do in the HP-22: https://neurochrome.com/products/hp-22
Tom
Tom
I'll second that, they are surprisingly good.You can try TDA2822M or Similar chip.
Lots for sale I see as kits and boards, just do a search for TDA2822 headphone amp. I built one ages ago using a Maplin PCB. I still have it in a drawer for testing stuff, runs off 9v (PP3). What more could you want.
One practical point, be sure to protect any input (and this applies to any solid state/chip device) from possible high voltage spikes from any non terminated output coupling caps in your valve preamp.
Tom
Thanks Tom! It was me that just bought a copy of your HP-22 board yesterday.
100 ohm output resistorI'll second that, they are surprisingly good.
EDIT: ok maybe 100 ohms is too much but i would recommend an output resistor when driving headphones with a chip amp
- Chip Amps
- Newby at chip amps, adding a headphone jack to a preamp
