Newbie to tubes, what can they handle?
Hi Guys,
I'm a fairly experienced solid state guy (chip and discrete) but I'm just starting to get into tube amps as I need a guitar amp. So this question might be aimed more at the musicians out there. I just started playing guitar again (I was a bass player for many years) and I am in need of an authentic vintage overdriven tube amp sound.
I'm running a DBX tube preamp (single 12AX7) into a peavey keyboard amp. To get the sound I want I'm massively overdriving the input to the preamp. It sounds fantastic although needs a little EQ and some reverb, which the peavey provides.
My question is, do I need to worry about blowing the preamp unit? It's powered by a 9V adaptor, so I'm not very worried. I doubt that 9V, no matter how its biased, could hurt the tube. Am I correct in this assumption? Should I worry about anything else?
Pete
Traitor.
Tubes can take a lot when used like that. Don't worry about it, but don't limit yourself to the 12AX7 when/if you start to build your own designs. It's crap, and I only use it in designs because of market demands and availability.
