I just finished building the PS for my F6 project. Using the Universal Power Supply board, I stuffed it with parts from the BOM in the build here:
https://cdn.shopify.com/s/files/1/1006/5046/files/P-PSU-1V30-bom.xls?15967766640867126881
I'm using an Antek AS-4218 (400VA, 18V).
I'm getting 26.8 volts out of each side. I was expecting 24.
Is this going to be too much for the F6? If so, should I chose differs values for R1 through R8?
BTW: I'm using 25V 15,000uf caps.
Thanks,
Peter
Thanks,
Peter
That's cutting it pretty close...in the future you should probably buy something in the 35V-50V range just for safety.
Not they're going to blow up or something if you exceed their rating.
What does the Voltage Rating on a Capacitor Mean?
