I am building my first preamp, and I have chosen the Aikido. Now my questions is, where to put the volume pot? Do I put it on the line in or do I put it on the line out? And if you could give an explanation on it, would be great. Thanks! 🙂
In.
You want to keep the output impedance low and constant- inserting a pot there will cause a low, constant output impedance to be higher and dependent on volume control setting.
