Hi all,
Here are some links to images of my newest conquest! Definately light years ahead of my first project.
ERROR: The requested URL could not be retrieved
http://img74.photobucket.com/albums/v224/GRaider/Image004.gif
Nice Job Gavin
And this is only your second major project I believe?
Keep up the good work Gavin. You did a nice job.
Re: Nice Job Gavin
Thank you Steve. All of the agonizing over parts selection and color and cussing....etc, were worth it. Now if I can be as successful with my 5687 buffered linestage I will be a really happy tubehead.
Positron said:And this is only your second major project I believe?
Ah ha.
Wait till your next project,
Just kidding. It takes along time to do things. I just spent several MONTHS upgrading my preamp. You are doing just fine.
Very pretty!
Signal lines crossing at right angles...
AC lines crossing at right angles...
Is that "Tea for the Tillerman" I see in the first photo?
Best,
George "Some Memories Are Forever" Ferguson
Best,
DrDeville said:Very pretty!
Best,
Hi DrDeville. That is indeed "Tea for the Tillerman". Good eyes!! I thought that I had done everything much better than I did with my first amp but you what? This amp has more hum than my first humble project does. Go figure huh? When I say hum I mean from the filament wiring. It is a very low level hum that you can only hear from about a foot away from the loudspeaker, which is 97 dB 1w/1m, so it don't take much. I'm going to run a voltage divider from the B+ to ground and bias the heaters up about 40 volts or so and see if that makes any difference. I'm also going to get a bright flashlight and see if I can spot any cold solder joints. The hum seems to subside somewhat after the amp fully warms up which tells me I have a bad joint (resistor?) somewhere. I may swap some tubes around also. Thank you very much for the compliments. Cheers.
Re: Great looking Amp...
No. I'm not that good at finish carpentry. I had a cabinetmaker that lives nearby make the frame and one for my planned linestage also. Any competent cabinetmaker should be able to build you a frame with dovetail joints on the corners. The cost was only $20.
mourip said:Did you make the base yourself?
That album is part of the music that is forever a part of my gestalt.
Indeed. I doubt you're discouraged, and you shouldn't be. As you undoubtedly know, there's plenty of things you can do--resolder joints, adjust the wire paths, use coax for the filament wiring, switch to DC filament power, etc. You'll get rid of it.
You deserve them. Thanks for the photos. 😀
Best,
George Ferguson
What a novel idea. Hadn't thought of that one. I solved the problem. I found that the 5687 I was using was microphonic. I also biased the filaments approximately 40v above ground. No more problem. You have to put your ear about 4 inches from the speakers to hear any hum or hiss. I can live with that.
G, GREAT WORK!! 🙂
The attention to detail of layout is truly a class winner in my strive-but-never-get-there dream of a 'professional' look both underneath and above.
DrDeville said:Congrats!😀
Why does biasing the filaments above ground reduce the hum?
Best,
George Ferguson
Try this thread. It will explain it better than I can.
http://www.diyaudio.com/forums/showthread.php?postid=90211
Thanks Gavin,
To save others digging:
From Sir Bas Horneman, I gather that electrons emitted from the heater itself can travel to the cathode, causing hum. Raising the heater bias stops this effect.
But perhaps the major advantage is preventing filament-cathode arcing in designs where the cathode can swing high above ground.
Thanks again, and I hope I got that right!
Best,
George Ferguson
Best,
George Ferguson
- Tubes / Valves
- New Tube Pics!!
