New toy: Fluke 6303a LCR meter
Good accuracy: 0.25% +-1 digit, capacitance 0.0pF-100mF, inductance 0.0uH-32kH, impedance 0.000-200M, also measures Q, Df, Rs. Selectable bias. Auto-trim.
Downsides: only 1kHz test frequency, level=2V, bias=2V. No fancy data port like the more expensive models in the line. My unit was also "well loved" but is less than a year out of calibration and matches my R,C standards.
I have a LCR meter
It is a good tool.
Mine is a yellow handhold of a not so expensive kind.
Wouldn't like to be without it.
It also measures frequencies
and other things a multimeter should.
Has PEAK and HOLD :smash:
I got tired of it running out of the 9 volts supplied by battery.
So I converted a flashlight charger into a battery eliminator
and drilled a hole for the wires to put in permanent power to it.
So now it can be left on 24 hours a day.
tiroth said:
$150 on Ebay. Seemed quite reasonable what with the more basic units running $70.
It does have Kelvin sense testpoints. I like the accuracy on your unit better though. 😉
That's a much friendlier DIY price. I seem to recall paying about $1400 US for the SRS model.
I will have to keep my eyes open for the Fluke model. Fluke makes good quality gear. My bench meter is an 8050A and I just picked up a 110 to replace my 8020B (display dried out). Top quality gear that just keep working and working.
Since we're whipping 'em out and laying them on the table, here's mine.
This is an impedance bridge that measures L, C, R/G, X/B, Q, D, Y/Z in series or parallel configurations. Freqs from 20 Hz to 150 kHz. 5mV - 1500 mV. GPIB. External bias supply port, tape drive, etc.
I picked it up real cheap (no, I mean really, really cheap!). Those of you who drool over this sort of stuff, keep looking. Deals are out there!
I will soon be doing an extensive set of measurements on my ESL 63s, and some home brew ESL panels and panels plus transformers to try to develop some models for simulation.
MR
Guys ever use this one???
Just talked to wife into buying me an LCR meter. Been wanting it for quite a while now, and will have to wait until X-Mas to play with it, Anyone have any reiviews to report?
It's a Tenma 72-920 (Also I think it's the same as some Extech, and BK precision units out there)
http://www.mcmb2b.com/cgi-bin/test/72-960.html
As for my favorite, I like the Sencore LC-102. I guess they don't even make it anymore, but it was a nice unit. It tested caps leakage, ESR, and capacitance at full voltage. Does similar things with inductors as well. It has the standard cap tables, and tells you if the caps are out of tolerance. I'd love to own, but a little to $$$ for my budget. Even at factory refurb prices...
-Dan
