New Subwoofer amps in stock
Hi Guys...
Just got in a shipment of NEW Class A/B Sub-Woofer amplifiers
150 W RMS @ 4 Ohm - APEX JR. MEGABASS II
115V/230V input switchable
Freq response 20Hz-160Hz
Signal to noise ratio >90dB
Speaker and Line level input
Built in Hi Pass Crossover 20 Hz (12dB/Oct)
Variable Phase 0-180 degrees
Protection: DC Short Circuit, Over Current,Overheat
Auto on off switch
Price $129.95 each
250 W RMS at 4 Ohm - APEX JR MEGABASS
Auto On Off Switch
Price $149.95 each
Yes, here are the spec's.....
Product details:
With Auto Power on/off select circuitry.
With Phase 0°/180°select switch & low pass Variable control.
With EQUALIZER control.
Use highly quality RCA input & Output terminal
Power 230V available
Protector :Output Short, over loads & over temperature.
Power & protect indicators
Specifications:
Output power: 250W RMS @ 4Ω
Total harmonic distortion: <1%
Line input sensitivity: 75mV
high input sensitivity: 2.0V
Signal to noise ratio: >90dB
Frequency response: 20Hz ~140Hz
Variable LOW-pass crossover: 35Hz ~140Hz (12dB/OCT)
Built-in bass booster: +7dB @ 40Hz
EQUALIZER control:20Hz ~100Hz&-12dB~+7dB
Variable phase control: 0° ~180°
Built-in auto power switch: ON/AUTO/OFF
Protect: short circuit, overheat
Operating voltage: 115/230vac
Yes, Still stock both types Megabass 250W and the MegaBass ll 150W RMS
Plate size is 10" X 10" on all 3 of these amps
250W at $149.95 and 150W at $129.95
And this Cerwin Vega 150W Amp Cost $99.95
Also The KRK amps I just posted yesterday in the Venders Section
KRK V 12S weighs 13 Lbs
Megabass weighs 14 lbs
what recommend me
1 x KRK -- V12s
or
2 x Cerwin Vega V-12S
You know wich cerwin vega model use speaker LSCTJ2090 that you have listed in your webiste?
Thinking about purchase
a few Cerwin Vega SL-28 Woofer to use in front channels, to use with Cerwin Vega 8 Ohm 5 1/4" LSCTJ2090 and twetter and a few Cerwin Vega 8 Ohm 5 1/4" LSCTJ2090 to use as center channel and surround channel but really scared about sound quality
or Cerwin-Vega 6" 16 ohm Woofer Good for MTM System $5.00ea.
really cant figure wich will be the best combo :/
