Hey guyz I am from India and new comer in DIY projector. I ve searched many things on internet and still confused about exact present scenario.
I ve a budget of 10,000 Rs. Please tell me what will I be needing to built the projector with exact things required or with model name of products.
And please tell me with the schematics of Box in which components will be established.
Please tell me I am very excited to built one.
For simplicity of perception I should tell you that I am an Electronics & Communication Engineer.
THank you 🙂
THank you 🙂
hello friends
i am Lokesh from india
i want to make a projector
i couldn't get the parts
I need your help
Where can i get the fresnel lens and triplet lens in chennai?
where is it available??
where the fresnel lens are available in chennai or india? (Specially in chennai)...
i need
two Fresnel lens of focal length 220mm and 330mm respectively.
and triplet lens 330mm
i am in need of it
were can i get it?
please someone help me.. and need guidance.
I need your help
i need
i am in need of it
were can i get it?
10k is a low budget.however if you can manage second hand OHP and a second hand lcd panel.......it will be under 10k.but it will end up as an experiment only.to enjoy what you will build.budget should be little high.so in my suggestion dont invest now.save money and then start your build.
hello friend
i am in little bit confusion
please clarify it for me friend
that is
i saw many videos in youtube about making of projector
and so i came to conclusion tat
1.thought of making projector with 15 inch lcd monitor
2 fresnel lens of 220mm & 330mm , triplet 330mm , light.400watts, and lastly wood shell
(thin glass,wood,fan,switches and all i have)
2.planned to get a 15inch lcd monitor(2nd hand) in my surroundings at cheaper rate.(Rs.1000)
3. light set also available in my surroundings(RS.2000)
4. so just planned to buy the fresnel lens and triplet lens alone in online(so estimated around Rs.3000 for both triplet and fresnel lens)
5.total cost i estimated is rs.7000
My Questions Are..
1.IS MY PLAN IS OKAY?
2.CAN I PROCEED WITH THIS PLAN & MONEY?
3.CAN I GET GOOD CLARITY ON PROJECTION?
3.CAN I MAKE THE PROJECTOR WITH 15inch LCD MONITOR?
4.IS MY TOTAL COST I PLANNED IS OK?
5.DOES THE FRESNEL LENS & TRIPLET LENS FOCAL LENGTH ARE CORRECT?
Please friend. go through my plan
and clarify my doubts.
waiting for ur reply.
lokesh
thisislokeshs@gmail.com
that is
My Questions Are..
lokesh
