Can't find any of these darn things anywhere!!!
I need a rubber band to replace the one from inside my old Wharfedale SYS 44 system, the CD player.
Any good sites where I can buy 1 from? Only after one that is 30mm
cpc do a selection of round and square section drive belts. This is a link to a 30 x 0.8mm round section belt:
https://cpc.farnell.com/unbranded/b...MIhbzYhsf94gIVAZztCh15tgWbEAYYASABEgLXqPD_BwE
Yes, they are quite universal, but it's best to match the thickness of the original belt.
One thing about the required diameter - the original belt will probably have stretched, so it may be a good idea to include a replacement which is slightly smaller in diameter (by a mm or two) in order to ensure a snug fit.
https://cpc.farnell.com/c/audio-visual/av-spares/belts-square-section
I used to have an old cassette player with a belt.
I couldn't get a new belt so just found one a similar thickness and cut it to length then superglued the ends.
I've recently restored a Sony MHC-5900 System and got mine from here.
Not cheap the whole kit with pinch-rollers for the decks.
http://www.hifiretroparts.com/belts/belts-for-sony-cassette-decks/belts-for-sony-hcd/
