There new amp out with the same chip as AMP5, called AMP10. And there is a new amp with the very good sounding and very powerfull TA3020 chip from Tripath, called "Truepath". The latter uses a 4-layer double weight PCB, so the shielding is optimal....
I've asked Jan about that, and he's supposed to be in the midst of working on a design that uses differential inputs but I haven't heard from him for a while.
And now Truepath is available. A 2x300Watt amp with TA3020!
A lot of power from a 10x11cm PCB!!
It seems it is going to replace the AMP2 kit.
Truepath has a 4-layer PCB to keep lead inductances minimal and provide maximum shielding 😎
I'll be ordering the AMP10 kit sometime soon... I need a new project and a little more power than the Charlize.
Good choice! If you still feel like more power you can get a second one and use them both in bridge mode (simple jumper connection...).
- Class D
- New 41hz amps!
