Description: Interconnect Kit for NEVE 51 series Preamp/Dynamic and EQ modules
Replace the EV10882 board, connect the modules , plug the Inputs and ouputs , plug the Psu that's it you got a Neve 51 preamp working.
Kit part list :
- 1 Interconnect board PCB 2 layers plated pads *for connecting:
• 1 Preamp/Dynamic module
• Micro ,Line and Key inputs
• PSU Bus , Dynamic link
• Signal indicator Threshold bus
• 1 Equalizer Module
- Interconnect board PCB 2 layers plated pads for connecting:
• 1 Equalizer module
• PSU Bus
• 1 +4db balanced output ( stage fitted on the PCB )
- 1 fully built and tested card to replace the EV10882 board
This board contains:
• 1 balanced +4dB SEND output stage.
• 1 balanced RTN input stage.
• 1 adjustable gain buffer for output stage.
- Connectors, components and ribbons.
(XLR and Jack Connectors not supplied)
Price for one KIT : 82€+shipping
Documentation here : http://andji2001.free.fr/KIT manuals/labo_k_effects_neve_51_kit_en2.pdf
Recapping Info : http://andji2001.free.fr/KIT manuals/NEVE_51_RECAPPING.pdf
Contact : labo.k@free.fr
speaking french (je parle français aussi)
2 kits on the picture
Kit part list :
• PSU Bus
Neve V Racking Kit
Description: Interconnect boards KIT for NEVE V series Preamp/Dynamic and EQ modules
Connect the modules , plug the Inputs and ouputs , plug the Psu that's it you got a Neve V preamp working.
Kit part list :
1 Interconnect board PCB 2 layers plated pads* for connecting :
*1 Preamp/Dynamic module
*Micro ,Line and Key inputs
*PSU Bus , Dynamic link
*1 Equalizer Module
1 Interconnect board PCB 2 layers plated pads for connecting :
*1 Equalizer module
*PSU Bus
* Send and return insertion
*1 +4db balanced output ( stage fitted on the PCB )
Components and kit connectors
49 € Plus shipping
Buyers can purchase the PCBs only : 30 € +shipping
Documentation here :* http://andji2001.free.fr/KIT manuals/en_kit_labo_k_neve_v.pdf
Speaking French (je parle Français aussi)
Kit part list :
*1 Equalizer Module
*1 Equalizer module
*PSU Bus
49 € Plus shipping
Neve 8108 Racking Kit
NEVE 8108 Racking Interface board
Description: Interconnect board* PCB for NEVE 8108 Preamp and EQ modules
Connect the modules originals ribbons , plug the Inputs and ouputs , plug the Psu that's it you got a Neve 8108 preamp working.
Interconnect board PCB* for connecting :
1 Neve 8108 Preamp module
1 Neve 8108 Equalizer module
+22v -22v 48v PSU
Instructions :* http://andji2001.free.fr/KIT manuals/Kit Labo K Neve 81 en.pdf
27 € plus shipping
speaking french (Je parle Français aussi)
+22v -22v 48v PSU
27 € plus shipping
Mounting clips for Neve V and 51 series modules.
These clips have been designed to allow the fixing of Neve 51 and V series preamp and EQ modules on the front panels of your racks.
Laser cut and drilled in steel 2mm thick they allow attachment to the fast, accurate and robust modules.
Mounting holes placed at the same locations as the original frame of the channel strip.
You just have to make two cuts with a saw on the screen-printed plate of the channel strip to fit the module.
Through these clips it is very simple to fix the modules on the front of your racks.
Unit price* 18€ + shiping
Attaches de fixation pour modules Neve series 51 et V
Ces attaches ont été spécialement conçues pour permettre la fixation des modules préampli et équaliseur des tranches de console Neve 51 et Neve V sur les faces avants de vos Racks.
Découpées et percées au laser dans de l'acier de 2mm d'épaisseur elles permettent une fixation à la fois rapide,précise et solide de ces modules.
Les trous de fixation son placés aux mêmes endroits que sur le châssis d'origine des tranches.
Il ne vous reste plus qu' à effectuer 2 découpes à la scie sur la plaque sérigraphiée de la tranche pour adapter celle ci au module.
Grâce à ces attaches il est très simple de fixer les modules sur les faces avant de vos racks.
Prix de l'unité 18€ + port
Ok sorry
How can i rename the main thread in "Neve 8108 , Neve V ,Neve 81 Racking Kits" ?
thank you
thank you
- Vendor's Bazaar
- Neve 8108 , Neve V , Neve 51 Racking Kits
