Neutrik 1/4 mono/stereo jack pinout help
I purchased these neutrik 1/4 mono & stereo jacks to replace the older ones in a guitar pedal i’m trying to bring back to life. i’m having trouble discerning what terminals are which and the data sheets i’ve come across don’t seem help much. could someone be so kind to tell me what the tip and ring pins are on the mono jack and what are the tip, ring and sleeve pins on the stereo jack? thanks alot in advance.
Looks like A is sleeve , and B ring and C is tip.
The connections on the other side could be the same but switched in /out.
For the mono socket, A is ground and B is tip.
Now put a plug in and confirm this.
