I'm a serial amp builder, and I assembled my dual mono Modulus-686 a few years back. It's an impressive beast, used off and on in various systems. With the many amps that I'm compelled to build, it's been sitting idle too much of the time. So, I've decided it needs a new owner who appreciates its many strengths.
Component list:
The total parts cost was CDN$3300, and I'm letting this go for just CDN$2200. (If you're in the States, USD$1600.) That's heavily discounted, and saves you the trouble and time to build it.
It's a heavy beast, so shipping costs will probably add another $200-300, depending on where you are. I'm willing to deliver it in southwestern Ontario, between Toronto and Windsor. Let me know if you're interested.
Component list:
- Modushop Dissipante 3U 400mm enclosure
- 2 x Antek 400VA 22VAC toroidal transformers
- Neurochrome
- ISS soft start
- 2 x Power-686
- 2 x Modulus-686
- 2 x Guardian-86
- Neutrik balanced inputs
- Neutrik SpeakON outputs, plus binding posts in parallel
- Front-panel pushbutton and rear toggle, configured as a 3-way power switch (for flexibility)
- High gauge silver-coated PTFE hookup wire
