Need a pair of lighter weight drivers to replace these in some 6th order ported (NOT bandpass) boxes so they need to be pretty close. I'd rather keep the existing cabs as they're a decent size.
Not asking anyone to search for me, just post if you happen to know one.
It would be nice if it were available from PE, US Speaker etc too.
^^ Thanks. I should have thought of that one myself. Bit pricey especially with shipping and taxes, but makes enough weight difference to make it worthwhile. This application is for my 3 way bass guitar cab, and the extension cab. Might just buy one for the main as the few gigs I've done lately have been small I'll deal with the added weight of the extension when I rarely use it.
Brett,
The Eminence Kappalite 3015LF Neo 15" is lighter (only 10.7 pounds) and cheaper than the JBL 2265HPL, might be worth a try modeling it in your cabinet design, even though the Thiele-Small parameters don't match the JBL2226.
Resonant Frequency (Fs) 44Hz
DC Resistance (Re) 5.5Ω
Voice Coil Inductance (Le) 0.93mH
Mechanical Q (Qms) 8.97
Electromagnetic Q (Qes) 0.48
Total Q (Qts) 0.46
Compliance Equivalent Volume (Vas) 5.33ft³
Mechanical Compliance of Suspension (Cms) 0.14mm/N
BL Product (BL) 17T·m
Maximum Linear Excursion (Xmax) 9.6mm
Surface Area of Cone (Sd) 881.1cm²
Total Q (Qts) 0.46
^^ Thanks for the suggestion, but I need an Fs of about 40Hz and a Qt of 0.3 for it to work in the existing 6th order box.
Worth having a look through the SB Audience speakers -
Rosso 15MW500 looks close(ish) and the 15SW800 has a low FS but is a sub rather than a woofer if that is an issue. IIRC these tend to be fairly priced and are starting to get good reviews.
SB Audience :: Official SB Audience Website
$198 from madisound - SB Audience Rosso-15MW500 15" Mid-woofer - note the TS number on the Madisound site are slightly different to the SB Audience site.
Did a quick overlay of the frequency responses and they are almost identical.
Thanks Ugg10 as I'd only briefly looked at those series when they were first released, but as I have about 200 good drivers on hand wasn't interested in any more so didn't look closer until now.
I appreciate the suggestion but neither is lighter than what I have and I'm happy with that, bar weight.
- Neo driver with same specs as possible to JBL2226
