Need volume control on active filter
Hi ! I have built an active high pass filter exactly as shown in the figure below for my UCD 400 amp. ( figure done by Collo from his website)
I wanted to add a volume control. I wired RCA input---> high pass filter ---> potentiometer. But the volume is so low that i have to put my ear on the speaker to hear. The output from the high pass filter is connected to input of the pot. The wiper/output of the pot is connected to the input of the amp. Ground of the pot and the high pass filter are connected together. May I know what i have done wrongly ?
Is there a way to add volume control to the circuit above ?
First check if you have 0V DC at the output, or close to it. If you have a large DC (more than a few 10s of millivolts), check your circuit connections, especially power supply.
The filter circuit has a gain of unity, so it should not be reducing the amplitude of anything above its cutoff frequency. What frequency is it set to? If you are not driving a tweeter directly (which could be damaged by low frequencies), bypass the filter and go directly from the source to the potentiometer and see what you get.
