need some advice,low budget psone pj
i built a psone pj from the parts below, i know you think it would look like crap but sprisingly looks good, even can watch it with a light on. and i built it under $90
what i really want to know is can i use the fresnel lens from ss and a staples fresnel with decent results? which lens would go where?
also im using a dimmer with the lighting to get 82 volts, im acually running it at about 75v. would i be better off using a diode? will reducing the volts kill the bulb faster or make it last longer?
anyone know of a better bulb i can fit in that fixture, the one in it does good but its only rated for 35hours.
psone screen $35
lexan xl10 (i thought this took part of your light, mine looks clear as glass)
http://www.surplusshed.com/pages/item/m2407.html
http://www.surplusshed.com/pages/item/l3384.html
http://www.surplusshed.com/pages/item/l3606.html
also a paper thin junk fresnel
this was just a test to learn alittle about optics and pjs, and just like ive read a million times im not satisfied. im going bigger and better soon, but id like to use this in the kids room or bedroom till then.
thanks for any info you can and have provided.
