Hi everybody, I'm a new member, nice to exchange experience with everybody.
Now I need your help, my sansui 5000x had problems about the sound, so I need the schematic to fix it. Please help me!
5000X is a receiver that was known for it's amp problems.
Sansui used to sell complete boards of a revised design.
I suggest you contact Sansui.
Thanks for your suggestion, but I think It's disconnected by Sansui for a long time ago. How do I contact sansui?djk said:5000X is a receiver that was known for it's amp problems.
Try at http://www.sharefx.com/index.asp?tab=today
Nice guys there, if it's around you will get it after a request.
Good luck
Ebbe
Good luck
Ebbe
I have the manual but its 50Mb and thus quite impossible to mail.
I bought it from www.vintageaudiomanuals.com.
Have a look at this thread as well:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=66186&highlight=
The 'Exclusive Sansui' forum at Audiokarma has a lot of info too.
/Hugo
/Hugo
es44 said:Try at http://www.sharefx.com/index.asp?tab=today
Good luck
Ebbe
Thanks es44 very much,I'll try
Netlist said:I have the manual but its 50Mb and thus quite impossible to mail.
/Hugo
Hi Netlist, thank you, but I only need Its schematic, can you take a picture of it?
When I play music, Its sound is not clear, sometime generating clapping sound at 2 speakers. It wrong 6 months ago. I'm very like sansui 5000x, the tunner is good, Its sound is nice, like tube. I conbined it with sansui speaker SP-30, the sound is soft but bass is not deep. So when my sansui 5000x is ok, I will find a larger vintage sansui speaker.
Do you have any experiences about this wrong?
For ease of faultfinding, does the clapping sound occur when you connect a source (cd-player) to the AUX input? This would rule out the tuner part.
Does the problem occur when the amp is cold or rather when its warmed up or always?
/Hugo
/Hugo
Netlist said:For ease of faultfinding, does the clapping sound occur when you connect a source (cd-player) to the AUX input? This would rule out the tuner part.
/Hugo
Both.
/Hugo
Both, but when its warmed up, the problem occur more frequent. Is capacitor too old (dry) cause this problem?
I the problem occurs at the same time in both channels on the AUX input I would suspect a power supply problem. Tighten the screws (if any) of the power supply caps, tighten the screws of the output transistors and hunt for any bad solder connection. See if the different fuses make good contact with the fuse holders.
/Hugo
/Hugo
Sorry, I describe not clear. Its sound is not clear at 2 speakers (I think I can fix it by replace old resistances and old capacitors and check power supply).
Sometime generating clapping sound on left channel (1 speaker)
Replacing caps is probably a good thing but I rather suspect a bad connection or even a small signal transistor.
/Hugo
/Hugo
Or have a look here:djk said:5000X is a receiver that was known for it's amp problems.
http://www.robertreznik.com/sansui/sansui.html
/Hugo
- Need sansui 5000x schematic
