Did anyone retain the info for the Atlas 15 subs? I'd really like the plans for the ported enclosures and sealed if you have them, just in case I change my mind.
Thanks!
Thanks!
Atlas 15
How to wire the Atlas 15 for a low Qts of .37:
LOW QTS: WIRE BETWEEN GOLD TERMINALS
How to wire the Atlas 15 for a mid Qts of .46:
MID QTS: 1.5 OHM 10WATT RESISTOR ACROSS GOLD TERMINALS
How to wire the Atlas 15 for a high Qts of .57:
HIGH QTS: NOTHING ON GOLD TERMINALS
Atlas 15 inch ported enclosure recommendations -
Enclosure size 11 ft3 8 ft3 6.5 ft3
Port tuning 16 Hz 19 Hz 21 Hz
Power handling 250 watts 300 watts 300 watts
Atlas 15 set to Qts of .37 for above alignments
- Sealed alignments for .37 Qts setting -
Enclosure alignment Q .577 Q .707 Q .9
Enclosure size 6.5 ft3 3.7 ft3 1.9 ft3
Power handling 200 watts 300 watts 350 watts
Sealed alignments for .45 Qts setting -
Enclosure size 16 ft3 7.8 ft3 3.7 ft3
Power handling 100 watts 175 watts 300 watts
Sealed alignments for .57 Qts setting -
Enclosure size N/A 16 ft3 7.8 ft3
Power handling N/A 100 watts 175 watts
