Hi im pretty new to this. I have done basic repairs in this amp before such as mosfets and sound chip using this sites search for some of the basics. Recently the crossover control broke off and I can not find any supplier where I can find it and the only thing marked is b10k on the back. Could anyone lend me their assistance?
I dont believe so, it looks like 15mm long also it is 12 pin all pointing straight down. Thank you for helping me ive been lost on trying to find a matching part.
Sorry actually going back and looking at some others I see I measured from the wrong place. looks to be a 10mm length 6mm diameter.
If you could find a single pot with the same design, you may be able to swap the boards out of four single pots into your pot.
There's also the option of replacing the pot with fixed resistors. It would make the crossover frequency fixed at one frequency but you could use the amp.
- General Interest
- Car Audio
- need info mmats d300hc
