Need help with output transformer for tube mic pre
I have a Hamptone HVTP2 tube mic pre amp. I want to try some vintage altec transformers in place of the Altran 4:1 output transformers. Specifically, the Altec 15095(a). The Altran’s are nice but too clean for the sound I want from this Pre amp. This mic pre was featured in a tape op article and the designer, Scott Hampton, actually mentioned using the Altec 15095 for the output yielded great results.
My question is in regards to the difference between the Altec 15095 and the 15095a. Scott used the (a) version in his prototype that he mentioned in the article. I want to know if I can safely use the 15095 non (a) version in this design. The (a) version Scott used has an independent grounding pin, while the non (a) version’s grounding pin is tied to the primary. From what I can tell by the looking at the schematic for the Hamptone, it’s output transformers have a grounded primary. Here is a link to the schematic. https://tapeop.com/_m/photologue/photos/vacuum-f1.jpg
Am I correct that I can use the grounded primary 15095 without a problem?
Thanks,
Matt
