I picked it up used and I'm getting no sound. The green LED comes on and the relay clicks. I checked the fuse and it's fine. There's no obvious damage to any of the boards. Any help would be appreciated. thanks.
Check the voice coil of the speaker, it should read around 5- 6 ohms when not connected to the amp. If it reads open, it's probably been cooked.
