I am currently rebuilding two Hafler DH-500 amps, using toroidal transformers, Fred rectifiers and Musical Concepts PA-3E boards
with black gate caps, and 4 - 39,000 uf main caps per amp. To be used to bi-amp my SDA-SRS speakers which I just purchased on e-bay and have since reworked with new mils resistors and Polyproplyene caps
I am looking for a state of the art power supply -+ 95 volt for the
front end, low level and drivers. I plan to leave the Mosfets unregulated.
I have built several power supplies, based on Boak, Sultzer and Jung designs . Using NE-5534 and LM317-LM337's and floating zener designs, for other Hafler, Dynaco 416, Leach Super Amps, and the Marsh pre-amp about 20-25 years ago. But haven't done much since then
What is the power supply design that will give me the best
results, for my new system. Also I need advice regarding removing
the resistor that separates the Mosfet drivers from the front end
My Initial aproach is use the LM317 and LM337 and float them
using a Zener String using seperate 5-10 volt transformers coupled to the main transformer to give a voltage boost ,rectify and regulate all with a common ground
I would appreciate any advice that anyone has.
Thanks,
Bill (wrich22)
Louisville, Ky
Thanks,
Bill (wrich22)
Louisville, Ky
For a high voltage regulator have a look at
Fig. 11 in Linear Technologies Application Note 2, August 1984, Performance Enhancement Techniques for Three Terminal Regulators.
Also
National Semiconductor Linear Brief LB-47, March 1980, High Voltage Adjustable Power Supplies.
For more advice on the amp consider a posting in the Solid State section of the forum.
Good luck,
G.
Also
Good luck,
G.
This one might be helpful:
http://www.glass-ware.com/tubecircuits/High_Voltage_Regulator.html
Basically identical to what a LM317 does... and with a little redesign one could get away with no extra supply for the regulator.
- Klaus
- Klaus
How about the psu-part for Balanced Line Stage / BoSoZ? (with a couple zeners extra)
http://www.passdiy.com/legacy.htm
Arne K
Arne K
