Need help finding out about Lanier 4320V projeciton panel! Help!
Has anyone here heard about the quality or know the specs to the Lanier 4320 lcd projection panel? It is being auctioned on ebay but I can't find any specs around the internet for it.
It has "true color" written on its box, so that should mean its 24-bit color right?
I know its 640x480 native but I can't find the contrast ratio or response times for it.
Your help would be gladly appreciated.
If you know the quality of other lanier models that would be helpful too!
Can't tell you much about it, other than it is a Proxima branded by Lanier. I've got a model 4315, and from posted photos it looks just like a Proxima 810. I disassembled mine, and from what I found mine is a passive matrix 640X480, although some posts here say that the 810 is active...not to sure about that. I just recieved pinouts for a way to convert an AT mobo power supply to fire this up, if I ever figure out how to make the 25pin connector hook up to my PC, then I'll know everything. Hope this helped some.
