Need help : DIY Fm car receiver
there not really that simple to make... especially if your trying to clone a headunit.
Phillips make a few digitaly controlled fm reciecers especially for car. If you after an analog control I would go and search google.
You'll find tons of info
try this
I don't know if this is what you're after but try........
http://w1.85920178/rx/tda700.htm
this site gives a schematic for the phillips one chip fm radio the TDA7000
if this along the right lines then logon to......
www.maplin.co.uk
then enter YY70M into the product search. this will give you a nice 12v 20w amp. the TDA2005M
then why not be really cool and get the bass,mid and treble controls using WQ31J in the product search. this uses a couple of LF353N chips.
maplins also sell the tda7000 but haven't got a schematic for it. the product code to enter is YH87U
if you do a GOOGLE search using the chip numbers you can get loads more info on them.
hope this helps
