hi,
installed elso kwak clock (with pcb) but cd player (marantz cd63se) wouldn't spin now.
on the few occasions it does spin it behaves strangely.
it goes clockwise for a while then anti-clockwise.
or spins very fast.
or spins very slowly.
"googled" and read that its probably due to the cdp not receiving the clock.
i've tried both the original crystal and a new one to no avail.
need some debugging tips.
thanks.
or spins very fast.
thanks.
Hi atenolol50,
did you desoldered the caps from the original cristal pins to ground , and resistor?
If yes , did you reinsert they in the circuit after the KWAK experiment , retrying the original cristal?
Inserting the KC have you used the 1k series resistor to check the input in the processor ?
I also had this with my CD10 and with a CD16. Put the 1MOhm resistor (probably smd) back in place. Then it´ll work.
I suppose you converted it along the LC-Audio guidance? I told them about this mistake but the only anwer was "can´t be"
William
William
i followed the instructions from www.diyparadise.com/clock.html
what wire should i for the clock output?
i'm using a single core cat5, is this ok?
If the wire is short (<10cm) it can be ok.
Where are you connecting the clock's pcb ground? at the player's psu, at the old cristal location, at both?
Bricolo said:If the wire is short (<10cm) it can be ok.
pcb gnd goes to the cdp's chassis, which is earthed to the IEC gnd pin.
Best to connect the PCB ground with the twisted wire or coax that also connects the clock (ie close to the original crystal).
Doing so will assure the RF currents will nicely stay together. If the power supply is OK, only DC + clock will run there.
succes
KC not working
Hello atenolol50,
First if you have a scope check if the clock is working. Did you adjust the duty cycle? Do you have +/-5V at the output of the regulators?
If you have no clock-signal check if you have a clock signal at the source of the FET. If not, you probably have fried the FET.
I advice connecting the ground of the clock PCB to the ground of the CDP PCB. One end of the two small caps attached to the original crystal was connected to ground. You can use that pad.
The clock output must be connected with one single wire to the players PCB. I do not advice twisted wires or coax!
If nothing works bring the player back to original state and check if it works now.
BTW I have sent you an email but I got no reply from you.............😕
Very strange.............
Edit:
I now did receive your email and I learned you have built version 6. Some players do not like the large caps notably Sony and CEC. Replace the 12000µF caps by a Oscon not larger than 220µF or a 47µF tantalum or 1 µF polypropylene.😎
Hello atenolol50,
Edit:
Go ahead.......hate me......
"The clock output must be connected with one single wire to the players PCB. I do not advice twisted wires or coax!"
And why is that? Inquiring minds want to know.
Jocko
Jocko
Re: Go ahead.......hate me......
I guessed you are in favor of that.......
ELSO/not one of the "twisted pair"...
Jocko Homo said:"The clock output must be connected with one single wire to the players PCB. I do not advice twisted wires or coax!"
Jocko
Or yours 😉
Atenolol50, did you change the cdplayer to its original condition and does it still have the problem ? I believe that is what you wrote in your first post. If so I am pretty sure that a chip has gone to heaven.
Optimal Results
ELSO/not one of the twisted pair
With the KWAK-CLOCK? [Elso's thingie in Jocko's wordsjean-paul said:
I always use coax as results are optimal.
Of course not, I use coax ( or twisted pair ) with *every* CLOCK I lay my hands on. The "single wire" method has the advantage that ground loops can not occur but I prefer both other methods with a separate supply. Galvanic separated that is, with a separate transformer and all.
BTW this discussion will not help the guy that wants to repair his cdplayer. I think he has a true failure and not a cdplayer that suffers from "twisted pair". 😉
Help
JP, I helped him as best I can in post #8 and in a private email.jean-paul said:
apologies, i didn't have a chance to test out the suggestions yet.
will do so and provide feedback.
i've just returned the cdp back to its original state.
its working.
will put back the kwak clock next and run the recommended checks ...
its working.
- Digital Source
- need help - cdp spin no more after kwak clock installation
