Greetings to Everyone !!!
I just acquired the FF from a friend and planing to build a class AB amp out of it:
Xformer: sec. output 21-0-21Vac rms @ 10 Amp sec. rating
Reservoir Caps: 18,000 uF 45 V
This would yield to +/-30 V DC rail.
with 8ohms load, maximum RMs power I can get from this is =(30-2*30-2)/8 = 100W
Current needed = sqrt(110/8) = 3.7 Amps which the xformer is capable of delivering.
Are my computation correct?
Any suggestions on the circuit I need to build???
Can I use this on Leach Amps? M250? I appreciate any help or any diagrams you can share!!!
Thanks,
Naldy
Thanks,
Naldy
naldy said:Xformer: sec. output 21-0-21Vac rms @ 10 Amp sec. rating
LM3875 gain clone -- caps are perhaps a bit big. More like 40W/channel thou.
dave
lol .. funny how one of the universal solutions to "what amp i should build" is gainclone 🙂
but seriously .. that seems like a good xformer for a gainclone 🙂
almost the 22V prefered by Peter ..
Sorry,naldy said:Greetings to Everyone !!!
100 W is correct if it was DC power you're talking about. You have forgotten a "2".
28^2/(2*8) = 49 W in theory! The amp can't deliver 28 volts peak if the supply voltage is 28 V! You will loose some voltage depending of amp design.
Power in is approx. 70-80 W
naldy said:This would yield to +/-30 V DC rail.
RMS power on 8E is P=Veff*Veff/Z,
Veff=Vmax/1.41 = ca Vcc/1.41
P=ca 50W
look this amp too; http://sound.westhost.com/project3a.htm
Thanks for all the inputs!
forgive my math...
so indeed I can have >40W of power from this PS.
I'd like to try IC gain clone but I've got 3 pairs of motorola
xsistors MJ15015/16 for the output stage. 😕
I like moamps recommendation though it lacks some short protection circuit.
forgive my math...
