Need advise of kit sounding similar Harbeth Expression
Hello guys! I want ask you of your advises)
I want to build speakers which sounds like Harbeth Expression\HHB Circle 5 studio monitors.
I want buy a ready set kit.
I will use them as desk speakers in nearfield zone.
I need tight, open, clear, sound with good microdynamics and controlled bass.
Sound with lowest distorsions and perfect non fatiguing imaging, which you can listen to all day.
Here is the video, where these monitors playing, where you can clearly hear exemplary sound YouTube
Thanks for response.
Not sure how that would benefit you, you would have no control over the recording conditions, and the equipment involved, you would also need to provide a good quality sound file yourself, that you know well, to have a proper frame of reference. Not realistic to expect the result of your dreams from a video playback.
Direct link to the kit:
Continuum II, Bare Bones (Pair) - Meniscus Audio
One of the more sought after kits from Jeff Bagby which models the LS3/5a system originally designed for the BBC in England. See the write-up in the pdf below for design details.
