hi all....
I need some help trying to find a lcd with a minimum of 640 x 480....with a goal of getting a 800 x 600....any way when i check specs of certain Lcd's they have specs like.....
600 (h) x 234 (V) pixels.......huh????
and sometimes i get 166660 colours or something like that.......or this
Resolution (dots): 960 V x 234 V = 224,640 * Dot Pitch (mm): .107 W x .316 H * Contrast Ratio: 80-120 * Response Time (ms): 30 Rise, 50 Fall
also should i get a widescreen lcd?
can someone outline what i should look for in a 640 x 480 display and a 800 x 600 display because i'm going to buy a new model lcd and and getting really confused when they list the specs in the above format instead of the traditional format of 16 bit and res......on parts express website they have some lcd modules listed ....what would you recommend. The lcd projector i what to make is the box type with lens.
