Need adjustable LPF for sub...
Hi everyone,
I am looking for a low pass filter circuit that has an adjustable crossover frequency from about 40Hz to 150Hz. It will be used for a sub project, I already have the summing buffers and phase reversal circuit. Can a 12dB Linkwitz-Riley (hope spelling is correct) be setup to be adjustable using dual pots? Anyway, it doesn't matter what alignment it is as long as it has an adjustable frequency.
Thanks in advance!
JojoD
Give it some thought. Even though the two pots won't track exactly, it could be useful. If you are crossing at 60Hz that 150Hz fixed frequency pole won't help in that critical transition region. Mismatched poles at 60 and 70 would though. You know your application though so if a simpler solution works, by all means go for it.
