need a thermoplastic adhesive to hold a heatsink screw
Here's the situation. My P101 heatsink taps are hopelessly filled with arctic alumina and would not retain a screw even with a threadlock compound.
I want to use that whitish "goop" sometimes seen in commercial amps to hold cable bundles together at the edge of a chassis or PCB. Specifically, I'd like one that I can later soften with a soldering iron. My hope is to just place a dollop of it at the heatsink screw head, on the top side of the PCB, to keep the screw from slowly unscrewing itself, which apparently it does. Does anybody know what that stuff is? I'm pretty sure its a kind of silicone, but harder than the typical caulk from the hardware store. But maybe it is some other kind of adhesive.
This chart leads me to think a "toughened" acrylic adhesive might be good for me because it can bond metal to plastic. Anybody know a brand of this?
Thermoplastic Adhesives
Maybe Locktite
But the usual type is used at screw/taphole
To be used on the outside, it is a special type you ask fore
I have seen something like that used on motor cycles
But maybe mostly to see if a screw have loosened
But I bet selflocking shims will hold it tight, nice and easy 😉
