Need a Infinite Baffle 10Inch
I have a Audi A5 with a infinite baffle setup. the cars oem sub is in the rear shelf.
Its weak and lets down the sound of the rest of the car. I want to know whats a good infinite baffle sub 10 inch i can swap it with?
I will also be sealing the boot better and covering holes in the shelf.
My budgets only 100GBP not much I know I might stretch it if theres something good but I just want to get rid of the distortion.
Thanks in advance
Ultimax 10" from Parts Express is ~$150, which will probably be over budget by the time you include shipping and duty etc. It has a Qtc ~.5, almost 20mm of excursion etc. Should be a good choice for IB. Peerless by Tymphany 830668 10" Paper Cone SLS has a high Q (.55 I think) but xmax is ~8mm, which might cause you excursion issues. It is only $60 though if you can deal with the limited output. Do you know your limitations in terms of mounting diameter? How much power will you be feeding it?
