After Googling and getting nothing I've turned to my favourite forum to ask if anyone at all has had any experience, or even heard of Nagaoka CD players?
Searching these forums brings up Nagaoka alot in the Full Range section but very little else...!
Will be waiting to see if any of you enlightened hi-fi folk know more than Google does! 😉
The 'Nagaoka Na-7700 Compact Disc Player Delta' would appear to be extremely rare. It was manufactured in 1987, retailing at £749.99 and was regarded as 'Top Pedigree' by 'Which Compact Disc'. Any further info just ask.
It's not for sale
The price quoted was the original selling price in 1987. Being so rare it could be worth 10 times that. Dear me, don't you people read English?
From the listed chipset & laser, it should be more or less a clone of a Denon DCD1700, which ain't bad.
I have it listed on ebay now
Don't know about Denon unless they were around in 87.
Played through Onkyo and Bose this remains a brilliant cd player. The track loop function is great for those wishing to play or sing along with. Tracks can be programmed to play in a desired order, repeated or excluded altogether. I bought it new along with a pair of Infinity Qe Speakers connected to a quad valve amp sounded sweet.
Hello,
i am searching for a service manual for my dbx dx900. Can everybody help me?
The Problem is that the player reads sometimes no discs an sometimes he "jumps" randomly in the tracks. 🙁
In the Player is a trimmer labeled with Track, so can i adjust the problem?
Regards ........Carsten
Don't twiddle without fully knowing what you are doing.
"Track"... tracking balance ? Tracking offset ? Trackinging gain ?
Will it fix the issue... probably not. You need to use a scope and see what is happening and also confirm the quality of the RF signal from the pickup.
If it is jumping the problem may be mechanical such as dirt/grease on the pickup sled.
Thanks for your answer.
no no i don't adjust something without the correct values for measuring, a scope is here.
The only thing what i have done was to clean the lens with alcohol, nothing more.
Ok, i will look to the mechanics and maybe i will clean them.
Any hint for me to get a service manual, dbx doesn't answer my question for an service manual or a repair shop in germany. :|
Carsten
Carsten
I've no idea where you would get a manual but if you have a scope you should be able to pick up the RF easily enough to check the quality and amplitude.
If you are not familiar with CD adjustment then I recommend you read a few old service manuals such as Sony CDP101, Sony D50MK1 etc and familiarise yourself with the adjustment names. The basics for adjustment are similar for most players and only require you to identify the appropriate test points which can be helped by looking up the data sheets for the IC's used.
That said unless you are confident in your abilities then you may end up doing more harm than good. Always mark the position of all the pots first too.
Thanks,
i will look first at the older/other models like the sonys.
Marking and measuring (writing it down) at the pots is the first thing. 😉
dbx has now answered but they have no service manual (the dx900 is a labeled kyocera da-9cx) .....
Thanks,
Hi Carsten,
could you find the Service Manual or the wiring schematics? If yes where did you find it? For repair of an Kyocera DA-710CX I am searching for the wiring schematics.
Any hint or information is highly appreciated.
Best regards
Arno
NRW Germany
Hi Arno,
after some study about these player i thought they were all identically. But the 710cx is a little bit different so i can't use these manual for my dbx.
In short i have found a "paper manual" without these player in a second hand shop in berlin, please write me an pm. 😀
- Digital Source
- Nagaoka CD players...
