NAD T762 - no audio output?
Anyone have experience with the NAD T762. It turns ON and when I select the FM tuner, it displays the FM radio channel frequency and also the text messaging, however no sound is output to the speaker ports. No audio at Speaker A or B, or even at the headphone jack.
Are there fuses in the outputs or might the relay contacts be bad (destroyed)? Voltages present appear OK: +67VDC, -67, +5, +22, +12.
Anyone have a full schematic diagram and voltage chart?
Thanks for any help you might be able to provide.
