NAD 514 Mod.
Wijgers
I can send you the schematics of this player.Please give me the e-mail adress.
I used to own this player and modded it a little bit.
I put the clock,exchanged the electrolitycs.I also changed op-amps for BB OPA2134.
This is MASH DAC.The player sound quite good but lacks smoothness of mutibit DAC's (PCM63 or TDA1541A).
If you change op-amps be aware that some of the op-amps considered good might make this bright player much brighter.
For example ,with OPA2604 is sounded dry and sharp like a razor.
Very fatique.
Bartek
