O.K. so my NAD 510 cd player konked out. It doesn't seem to want to read cd's. Transport tray opens and closes. Laser head moves into position but doesn't read the cd. All I get is "No Disc"
Anyone have this problem?
The transformer reads 18-0-18 v and none of the fuses are blown. I'm not all that sure where the problem could be and I don't have a service manual to start pulling the thing apart.
Any help?
Cyrile
Any help?
Cyrile
Hi Cyrile,
If you close the drawer without a CD, does the lens move up and down? If you look from the side underneath, load a CD. What does the heat do?
-Chris
-Chris
NAD
Yes it does. But unlike when the fuse is blown it seems to be under control. What happens is that the drawer closes, the laser moves into position hops un and down but the disc isn't recognised so it doesn't do anything.
Is there a control chip that might be screwy? I'm not sure how to troubleshoot this problem, fortunately I have a backup Yamaha CD player but the sound is SOO different that I'd like to bring the NAD back to life, or maybe use the DAC from the Nad in the Yamaha...
Of course reviving the NAD is option 1.
THanks
THanks
Hi Cyrile,
Without a disc and clamper, look down from a distance greater than 16" and look down slightly off center. Load the tray and tell me if you see a red light in the lense.
You have not touched any controls, right?
-Chris
-Chris
No light at all from the head. It does move up and down.
Didn't touch anything. Other than changing the lamps for leds and changing fuses...
Hi Cyrile,
At this point it seems like the laser is not told to light. It shouldn't be a limit switch as the unit is doing a focus search.
So you need a manual to troubleshoot this CD player. A tech may be able to do more testing, but I can't see it on front of me to guide you.
If you can find R101 (?) , 22R, measure across it when the head is doing a focus search. Guessing here. No manual.
-Chris
-Chris
