NAD 304 schematic ???
I did search this site for the diagram but all the links were dead.
please mail to.....
stayforthedayandgo@yahoo.com
After the amp warms up one channel becomes distorted, I should be able trace it through if I had the schematic.
Thanks.
Dave
please mail to.....
Thanks.
Dave
If there is no schematic .. where should I start to look ?
After the amp warms up one channel starts to break up very badly, while the other channel suffers the same fault but only very slighty.
I have not yet opened this amp up to look about as without a diagram I would be lost.
Any suggestions would be appreciated.
I think the NAD's are riddled with elcaps, especially the line amp part. Check for dried out ones.
And me too
Hello
I also need NAD304 schematic to repaire burned power transformer of my father's amplifier (My younger brother had listened to rock music extremely loud). Could you send it to dnaishul@yandex.ru
Thank you, Daniel
Hello
Thank you, Daniel
hmm i got one of these too...so if anyone's throwing schematics around,i would be very greatful to get one as well...
i had some problems with mine as well,and i don't know if this would be the same or even related...mine just wouldn't turn on and got stuck in protection mode...anyway in addition to any other problems anyone's having... you want to double check the values and integrity of these components
preamp section- R917/R918 these are 180 ohm and should be changed to 1 watt if they installed 1/2 watt..check to make sure they work and aren't cooked if you have 1/2 watt's installed![some apparently do]
main Amp - R333/R334 are the same deal..47k 1/2 watt and should be 1 watt..these suckers get HOT,hot enough to discolor the PCB..these cause the "protection fault" when they let go and tend to drift up to very high values before...DEFINATELY check em and replace if necessary...from what i can gather this was a VERY common failure with this model..when blown the amp becomes completely non functional,but the fix is easy...just replace em,their failure doesn't appear to do any other damage 🙂
oops i forgot my email
if anyone would be kind enough to pass on the schematic,it would be most appreciated...
rodmowery@hfx.eastlink.ca
i should mention as well that the parts and fixes i mentioned in my last post are not just from my own brain and experience,but are reportedly from NAD service bulletins,factory recommended and approved as it were...for reliability these parts should be swapped/checked. 🙂
Hi, gentlemen
Thanks to you, I solved the problem with transformer, but suddenly got another one. The same as Man_in_UK - after warming up right channel becomes silent and distorted. If you have any experience, please share it with me.
Dan
Dan
Hello,
I just fried one channel of my NAD 304. I need schematic to repaire it. Could
someone also send me a copy of the schematic. Thank you very much!
YY
charng@phys.sinica.edu.tw
YY
nad 304
HI
If u don't mind ,
Please send it to me too.
Adress:
alizaa@netvision.net.il
Best regards
Dudu
HI
If u don't mind ,
Adress:
Best regards
Dudu
Rodzilla, I just wanna thank you for this information regarding the NAD 304 and the 4 prone-to-failure resistors. My amp blew up the other day, and whilst searching for a service manual, I found this thread (I've registered just so as I can reply!). I don't know electronics so I'd never have found it myself, but I checked all 4 resistors, and R334 was behaving odd. So I replaced it at the cost of 35p (well I splashed out on 2watt!), and the amp works fine again. So thanks for the info - saved me a bundle.
Incidentally, the amp went when I was trying out a new sound module I'd just received. The output was set to pan hard left. I heard a brief bit of the sound, less than a second, before it went. So I don't know if the 304 is prone to blowing when one channel is far louder than the other (which would have been silent). I'd consider trying it, but then like I say, it's a 2W one in there now anyway.
Thanks again,
Andy
Thanks again,
Andy
- NAD 304 schematic wanted
