Picked up one of these today for repair and it had the strangest plug on it, never seen one of these before ever.
looks more like it was for lighting
Same as mine ( a work colleague was about to throw it in a skip ), you need the special nad distribution block thing, then you'll be able to plug in several nad separates.
I had a mini power distribution block which came complete with these plugs.
It had the advantage of taking up minimum space in the tight confines of a small equipment rack.
Pain in the neck if you wanted to swap separates in and out of your system though!
