nad 2400 thx amp schematic
Does anyone have a schematic fo a Nad 2400 power amp,I have 3 units with the same problem of not coming out of protections.They do not have any dc offset and no fuses are blown.It seems to be a problem with the protection IC that drives the speaker relays.
nad 2400
Thanks,I figured out the problem.I had 3 of these to repair for a customer.They were all in protection but had no dc offset.The protection circuit was on because of C817 a 4.7 mfd was leaky.Once audio was applied both channels would go into protection because C818 was leaky a 220mfd.Also C403 and C453 was leaky in the diff amp cause protection with audio applied.In the power supply as preventive measure C810 and C811 was replaced because of open tops of the caps.They get heated up from the nearby regulators.These amps also have alot of bad solder connections that needed to be retouched.Its worth the time to go over the pcb and retouch any connections that appear suspect.
