Mystery circuit
My first post here, greetings to all.
I bought an electric guitar from Ebay. It has had an aftermarket circuit board installed. I am thinking it might be an onboard preamp, but I am guessing in the dark, as I haven't got much electronics knowledge beyond simple soldering of pickups/switches.
Here are some pictures:
I identified the two chips as:
MC1458CP1
and
NE571N
I attached a 9V battery to the battery clip and the diode lit up, then faded out. I think on off is controleld by a DPDT switch on the guitar. I think the cirucit may be an onboard preamp connected to the single"active pickup" which is itself powered by a 9V battery.
Perhaps someone can suggest what the circuit does? I can take more pictures if needed.
I would be very grateful.
Thank you.
NE570,NE571,SA570
is one Compandor.
Can both compress and expand dynamic range.
Just as guessed, this chip is often used radio communication circuits.
Probably: Compress -> Transmit -> Expand in receiver
http://www.nxp.com/acrobat/datasheets/SA571.pdf
The SA571 is a versatile low cost dual gain control circuit in which either channel may be used as a dynamic range compressor or expandor. Each channel has a full-wave rectifier to detect the average value of the signal, a linerarized temperature-compensated variable gain cell, and an operational amplifier.
The SA571 is well suited for use in cellular radio and radio communications system, modems, telephone, and satellite broadcast/receive audio systems.
Wow, my first guess may have been right then!
The only reason I thought it may have been the wireless is that the dude from Night Ranger has an internal Nady, and they looked kind of similar in their size.
The number on the silver thing says:
T191.300 (I think)
So I'd need a box that recieves the righ signal to test?
Re: the LE diode not functioning, would that be a problem do you guys think? It went on when I put the battery in and then faded instantly.
If you have not Nady 101 Wireless Receiver
you may search eBay for it.
I would not use wireless.
I would remove that circuit.
And use a good Guitar Preamplifier
(with your favourite effects) + shieded guitar cable with plugs.
One small Battery Amplifier ( 9VDC or 2x9VDC alkaline ) in your guitar to drive the cable.
And one PreAmp with 'fuzzing effects' at Power Amplifier input.
We have a special forum for Guitar Preamps and other Musical Instruments.
diyAudio Forums > Top >Other Stuff > Musical Instruments
Of course, for 'fuzz box' circuits you may also Browse our Tube Forum.
I both these forums are topics with links to good guitar circuit ideas.
Such circuits that are not too difficult for DIY Do-It-Yourself.
Here is one link collection for Guitar Circuits:
ePanorama.net - Guitar effect boxes
from the good site
ePanorama.net - Audio Circuits Page
Regards 😉
Lineup Audio Circuits
Thanks, LineUp...I am considering what to do. The review for wireless units say "it sucks your tone" etc. It seems I could get a Nady 101 unit pretty cheaply. But it would be nice to perhaps ditch it, as I would not really use it much, and install something cool in there. Not sure what though!
Oh and by the way, It is confirmed as a ?NAdy eve more now. Along the lip of the ruted sectoin some paint got chemically stripped as I was fixing up the body. Underneath the paint it said "INSTALLATION OF NADY WIRELESS BY G'S CUSTOM GUITARS".
So there we go!
