My Totem Arro 4 ohm load on KT-88 based amp
I have a Yaqin MC-100B which has served quite well
I've played around with only tube rolling and now it consists of:
Tungsol 12AX7s
Sov 6SN7
and stock Shuguang Grade 6 KT88-98
while playing around, I tried the 8ohm taps on my amp and have found a great deal of difference...
Almost more linear, but definitely more prevail ant bass
However the speakers are rated for 4ohm and I don't know if this will cause "issues"
I realize speakers impedance are just a subjective rating & that the way an amp utilizes the whole power transformer circuits running off the 8 ohm taps rather than the 4ohms secondary is likely why I'm seeing this difference.
However... How can I tell if I am pushing the amp to it's limit?
I've had to replace the fuse on it before, but I think it was related to a power spike... but I can't be fore certain
The Totem is rated 87db @ 1w
but is 4 ohm, and has a max power rating of 80 watts
The Amp @ both 4 or 8 ohm taps are 65 UL
So I'm thinking at my typical listening levels of around the 85 db in a relatively small room should not be drawing "tons" of power
but I do think the tubes do run hotter, as the cage gets even warmer...
At a listening level of 85-90dB, your amp is basically running at just above idle. I'm assuming you are running the amp in UL, not triode.
If it sounds better to you running from the 8ohm tap, them leave it there and enjoy.
Try removing the cage for better ventilation, although it may not make a difference.
Jeff
After calling around asking advice.. everyone says: "use what sounds best"
So tonight I again find myself favoring the 8ohm taps
However even after just an hour of playing music at a reasonable range... the cage & the heatsink'd area around the tubes were outrageously hot...
I know that's a "common" thing with tubes, but whilst running the 4 ohms taps at the same volume level (gain)... it wasn't getting this hot
Are there potential issues with this?
can't remember if I'm posting again or not
anyways, i've been running my amp for the last few hours off the 8ohm taps
sounding great
but after touching both the cage and the chasis (heatsink kind of thing) aruond the pots
I notice it does run quite a bit hotter
Over the last few days, I've measured the temperature of the heatsink by the tube pots and found that running @ 8ohms at the same gain levels is resulting in a 10c or 20f increase of temperature.
i.e 60 - 70c difference
What I've done was reduce the bia's from 5.8 down to 5.5 and have noticed that I've been able to reduce the temperature to half the rise, to about 5c
However this pot adjustment has gave me a bit more "Fatty" tube sound with a bit less bass presence.
However I'm still not certain whether I should reduce the bia's more to save the tube life?
Or if this increase in temperature is "tolerable" by my amplifier?
Also by reducing the Bia's do I reduce the total amount of current available? Or is that just a transformer thing?
Does reducing the Bias also save the amount of load on the transformer though I'm running the 8ohm taps?
If anyone can reply that'd be great
I seriously wouldn't be concerned about the amount of heat radiating from your amp, it has a lot of tubes crammed into a fairly small area.
Bias your amp for the best sound, don't be concerned about tube life. Unless there is a serious problem with your amp, you should expect thousands of hours of listening pleasure before any replacement is required.
I would encourage you to try running your amp in triode mode, either from the 4 or 8 ohm taps.
Jeff
I enjoy the Triode for intimate listening of Jazz and easy listening style of music
The melodic rich vocals and I think added decay and softness to the strings & piano is wonderful
However UL gives me more extention for other genres of music, plus I think there is added spacial depth
Message back from Totem:
although we do rate the Arro at 4 ohms, this does signify the minimum impedance
operation they nominally operate at 8 ohms + 90 % of the time. so your findings do make good sense
the HAWK on the other hand is a very constant 6 ohm load.
both loudspeakers are fantastic but the long throw woofer on the HAWK does tend to favor higher powered amplifier (for more control)
