on one of my subs of my main speakers, 12" whenever it hits a certain frequency i hear an annoying rattle or buzz, a high pitched rattling buzz..... how do i fix it?
i know i'm a newbie no need to re-state it...😉
First, are you absolutely sure that the rattle is coming from the sub? Sometimes, something in the room can resonate and it is very difficult to tell where the sound is coming from.
Assumiing that it is the sub, is it internal or external? If internal, then you need to remove the driver and investigate. Whatever is loose should be fairly easy to spot. Perhaps it can be stuck back in place with hotmelt glue.
The driver is usually held in place with nuts and bolts. The nuts are usually captive so you just have to undo the nuts and then carefully lift out the driver. Obviously a bit easier if you have the sub on its back so the driver is horizontal rather than vertical.
Good luck, it's probably nothing serious but you need to get it sorted.
