Here is the schematiccs for Little QUASi AMp in simulator it run fine with THD ratings as low as 0.01% lets see wat do experienced people have to say
regards
sekhar
regards
sekhar
Give it some emitter degeneration on the LTP & check the distortion then, should make the whole thing more linear.
100 ohm should be fine on each emitter 🙂
here is updated schematic as suggested by EVENT HORIZON .............. sorry to say but after addding the resistor in emitter of the LPT the THD rating actually increased from 0.01 to 0.03
regards
sekhar
regards
sekhar
the schematics
regards
sekhar
regards
sekhar
Try increasing the LTP tail current to restore the LTP gain to what it was.
Then try adding a low value emitter resistor to the VAS.
seems that I should go and make pcbs straight forward the design seems to good enough wat say every body any more modification needed ?????????????????
regards
sekhar
regards
sekhar
- my little QUASI AMP
