It has been some months since I decided to build me a GC based integrated amp so I went through a lot of reading, gathering info and data and building several types of popular GCs to find out what I like the best. And I found it. It is carlosfm's NIGC with low value resistors in feedback path + AD815 preamp. Of course, all spiced with lots of snubbers. I know it's a subject of many a dispute on this forum, but as carlosfm once said:" yeah, yeah, just try it ". And I did, and I was glad I did. My Epos M5 loudspeakers now really sing.
I've made a web page with schematics, some photos and comments (maybe it might help someone): In the meantime, the site went dead...
Many thanks to carlosfm for his enthusiasm and good will,
Chears all !
Chears all !
there is only one thing i dont like. why do you use thin cables for PSU rails -> amp and output -> speaker connectors?
in your place, I would use the same thickness cables of the output ones of the transformer for output & psu rails.
Thanks zafira,
actually building took 3 days of work, but experimenting, adjusting and searching for the "right stuff" took couple of months.
Those cables are not thin (AWG24 from IBM category 5e SFTP-Shielded, Foiled, Twisted Pair ethernet cable - very, very good conductors, I use them for speaker and interconect cables) and as you can see, for heavy load lines they are doubled (two paralleled) and of course, they are short (5-20 cm).
Cheers
Cheers
juma said:Thanks zafira,
Cheers
I didnt noticed that the cables where two paralleled. I have LOT of this cable, i didnt know that they were very very good conductors. I will start using them 🙄
Very Good. That is point to point gone extreme.
Did you get the output for the AD815 down to zero(no cap). The lowest I was able to get it is 25mv(not an issue I have a cap on the output). One thing I notice is that dc offset was not pot position depended,when it settled at 25mv it stayed at 25mv.
juma said:Many thanks to carlosfm for his enthusiasm and good will,
Thanks for your kind words, Juma.
And to give some credit to a lunatic. 😀
Btw I like your description of how it sounds (from your web site):
"The sound is what I hoped for: it's in a big boys' league! I will not give you the audio magazines' talk (detailed, airy, transparent, tight ...) but I can tell you this: if you know how the good jazz trio (acoustic bass, piano and drums) with singer, sounds in a good room, without any electrical equipment used, yes, that's pretty much it. I'm very satisfied indeed."
Now you need a good source component, and you'll fall off the chair. 😎
nice work.
copper heatsink??
its Good looking outside but dirty inside.
in all,what finally matters is how it sounds.u say it sings,nothing more is desired.
Keep it up.
copper heatsink??
Keep it up.
Re: Re: My Integrated GC - Tribute to carlosfm
No, it's not extreme. Extreme would be building a PC motherboard point to point 😀
And yes, I did got the output of AD815 to 0mV with Carlos' DC null circuit, but this needs time to settlle. Since this is an integrated amp, it has to be without any DC on power amp's input from the start (I don't want any time delay circuits), so I went for coupling caps solution.
If you can't get it lower than 25 mV, try widening the range of regulation - use 1K or 2K trims insted of 500R ones in DC null circuit. Also, make shure if the polarity of offset voltage is + or - (maybe you need to inject negative voltage).
Well Carlos, you were flamed fiercely few times on this forum for defending and promoting a very good concept.
You deserve the credit for that. In my country people say: "When one man tells you that you are a donkey, you shouldn't be upset. But when 10 people tells you that you are a donkey, you better get yourself a saddle".
But you didn't flinch. And you were right. I respect that.
Any suggestions in 500 EUR price range ? Or maybe building something based on PC CD drive unit (I notice that there are some very good ones - Teac, Plextor...)?
Cheers !
jaudio said:Very Good. That is point to point gone extreme.
Cheers !
juma
what is this?
you have to understand, you can NOT mess like this ...
what is this?
lineup said:juma
what is this?
Well, let me explain it:
what you call a mess is actually a superior application of a very advanced 3D building technique implemented in order to achieve a well optimized, specificaly purposeful mechanical and electrical characteristics of uniquely sofisticated aparatus of extremely high quality and value.
I stay open for further explanations 😀
lineup::::illegal page.
your 'essay' doesnt leave scope for any further explaination.
Hmmmm..... maybe envy???????
I built the Ni3886-AD815 pre combo but different setup (two monoblocks, each with dedicated PS and pre) and it sounds more that very nice... better chip amp I've heard (Gaincard, inverted low cap 3875, NI3875) astounding, clear and tight bass and all advantages from the GC league, although I'd not name it GC at all!
Carlos... go on!
Feliz año nuevo!
juma said:Any suggestions in 500 EUR price range ?
Maybe you could buy a half decent used CDP with a good mechanics (like Philips CDMx) and TDA1541A dac chip, put a good clock on it and work on the analog stage, PSU, etc.
As an alternative, a CDP with the PMD100 HDCD digital filter and PCM63/1702/1704 or AD1862 (I love it) dac chips.
Investigate, you'll find some players with these chips.
A used Arcam Alpha 9 CDP is also a good choice, if you can get it cheap buy it and mod it.
If you go for a separate transport/dac combination, a Teac VRDS-T1 with the Tent XO3 clock (with dedicated SPDIF circuit) is fantastic, and a good external dac.
New version built (regulated - LT1083)
After four months of further experimenting I built a new version of integrated NI GC. It was worth it. Look for details on:
http://free.hostdepartment.com/j/jrexton/
Follow the "Updated - 16. May 2006 - version 2 (regulated) - click here" link.
Cheers all !
Cheers all !
- Chip Amps
- My Integrated GC - Tribute to carlosfm
