After months of reading the threads in this forum and others and ordering BrianGT's boards and components (Thanks Brian!) I finished my first GC a couple of days ago. It uses a 225VA toroid (24V dual secondaries) and a 20k series attenuator (made with a shorting 11 position switch from electroswitch and Vishay Dale resistors- at around $30 its a great bang for the buck if you can leave with 6dB leaps in volume level!-).
On the first trials I heard a couple of "pops" coming out of the speakers. Not annoying but clearly there. The best way to describe them is like the pops that you get from a damaged vinyl record. Then nothing.
This morning the amp was on with no signal (the cd I played last night had finished hours before!) and I heard the pops again. Interestingly I noticed they happened when my wife turned on or off the bathroom lights. These lights are powered by small transformers. I tried repeating the experience and voilá, each time you turn the lights on or off the pop appears. I tried with different lights and it happens with those that are powered via transformers, apparently not with those powered directly from the ac lines (but have to verify this).
My only idea is that when the lights are turned on they draw so much current that momentarily "turn the amp off". I thus tried to replicate the sound by turning the amp on and off rapidly and it happens (I get some pops although not sure they're the same).
Supposedly the LM3875 does not produce on-off transients. Could this be oscillation? Could this be related with very small input caps that really doesn't store much energy and from a large energy draw from the lights? Could this be only some kind of noise in the lines induced by the lights?
Doesn't seem like they will damage the speakers or something (I use full range speakers so no tweaters!).
I will keep experimenting but any ideas will be mostly appreciated as I'm by no means an expert.
Thanks,
xavier
Thanks,
xavier
xcortes said:This morning the amp was on with no signal (the cd I played last night had finished hours before!) and I heard the pops again. Interestingly I noticed they happened when my wife turned on or off the bathroom lights.
Mine does the same thing. Except it does it when virtually any thing in the house is switched on or off and possibly also the neighbors house.
Not particularly loud pops, but annoying anyway. My valve amp doesn't let any of this through.
After receiving advice and trying a few things, I believe the reason is a lack of PSU filtering. The valve amp has much more series impedance in the supply (valve rectifier and choke) which is probably more effective at squashing spikes on the AC line.
You can try an encapsulated mains filter (the sort combined with an IEC socket.) I'd suggest getting a fairly good one rated for lots of current - 5 amps. This still may not work.
Other tries might be regulated supplies, a battery power supply, or a choke input supply. There is a way to suppress the offending spark at it's source which may be an option if only the bathroom light causes the problem, but you should have an electrician do this work.
did you try different grounding configurations? in mine all ground connections (including the attenuator ones) go to the same point. i'm thinking of connecting the psu and mains wire ground to one point and the signal grounds to another.
High gain, high current -- susceptibility to all sorts of nasties.
1) Check to make sure that all of the units are grounded commonly.
2) You might want to put an LC filter on the mains. A bifiliar wound choke on each line, a pair of 10nF caps (could be 100nF-- horses for courses) rated for the appropriate line voltage, etc.
3) Not entirely germaine -- but the reservoir caps should have 100nF bypass caps mounted as closely as possible to the chip.
Instead of trying to "roll your own" (and playing with mains voltages while doing it) - look for filtered power input modules (e.g. "Corcom") and perhaps supplement these with commonly available "surge protectors" (offered for use with typical PC's, monitors, etc.).
Winding your own inductors and then tacking on capacitors to create home made "filters" and other experiments is just asking for trouble if you're not VERY familiar with the techniques, the voltages, and the risks... I'd advise that you look for things which are commercially available and experiment with different combinations of those.
Just my $0.02..........
Your problem may come from the output also. If you don't have any output filter, the noise may be picked up by the speaker cables (long good antennas!)
How about your protective earth and signal ground?
naah, in this case it's pretty simple and the technique is described in virtually every ham radio handbook (and these are available at libraries everywhere in the civilised world) ... of course in the case of ham radio the problem is one of noise migrating FROM the equipment to the power line.
the other problem which I neglected to mention could be poor relay contactors in household appliances -- could be a design flaw or just dirt and old age -- the EU has very tough EMI standards but if an applicance is made in China, anything can happen. if there is a bum contact the electrical noise will propagate for several hundred feet from the source.
mine does the same too....
any switch on/off, pop or white noise if the switch is not really good(like the heater in one of my aquariums).
I knew there must be others having the same problem so I waited. Looks like I was right.
note: I have an EMI filter on the mains(the plug-in on the amp is a computer plug I got from an old unused PSU). I also have two ferrites on the mains cable.
please can someone describe the proper way of grounding? like grounding everything(inputs, amp boards, psu, mains) in star?
It also happens with my recently acquired phono stage (Lehmann black cube)!!!!!!!!!!!!!!
The good news is that the problem doesn't seem to be directly related with my gainclone 🙂
The bad news is that I now have to solve the problem for two systems!! 🙁
The appartment is not old but I've noticed many low quality construction and finishing materials in it.
Does anyone think that a filter such as the popular Jon Risch one will eliminate the problem?
What about the Auricap tweak installing two .47 uF 600V Auricaps in parallel with the red lead to the hot screw and the black lead to the neutral screw?
In the meantime I'll do two things:
1. Try a PC surge suppressor (I know It will negatively affect sound but it's a free experiment).
2. Measure if there are any AC voltage variations (peaks?) correlated with the pops.
Thanks all
Thanks all
I have no pops when I replace the transformer and rectifiers with a battery power supply - none. Therefore I strongly suspect that the problem is coming directly from the mains.
That Xavier's problem occurs in two systems with differing components, also seems to indicate a direct mains issue. I don't think improved grounding, etc. will improve the situation, not meaning to discount its importance, of course.
Note that while the PSSR of LM3875 is quite good at 120Hz, it is only 50-60db at 10kHz. Of course, at this frequency the PSU caps should be more effective. Is this true? Should the caps absorb a spike of this nature?
Ain't that "a bit" overboard?xcortes said:What do you think about using an isolation transformer?
I mean, 47Labs doesn't need such a device as I know it... Could it be that something is wrong with the design? It's sad that the designers of the gainclone are not posting on this matter. It is true, we didn't pay for support, but... still would be nice
Balanced power?
An isolation transformer may reduce the spike, but probably mostly because of the increase in series impedance the isolation transformer would give you. By design, I don't think an isolation transformer is supposed to help this situation. It's more of a safety device.
You could achive a much better increase with an encapsulated mains filter, but some people feel that placing series filter elements in a power amp mains connection affects the sound in a bad way. These may not do much suppression at audio frequencies, anyway.
I tried some mains rated caps across AC line and neutral to no effect. I suspect these would need to be rather larger than the typical values available to have much effect at audio frequencies.
Probably the best solution is a dedicated mains circuit for your audio equipment, well isolated from other circuits in the house - however this may not be a certain fix. Since I rent my house, I cannot do this.
pops because of bad grounding (?)
Review your grounding configuration. I've experimented with different groundings and I've found that some configuration was very sensitive to pops as you describe. Try the schematics I posted on
http://gainclone.com/phpBB2/viewtopic.php?t=260 ? this arrangement is very stable, no hum, ho his, and no pops, only high quality music ;-)
Perhaps the datasheet tell us more?
Why not consult the datasheet of the LM3875?
The solution for this problem is a simple 220pF capacitor between the + and - input pin.
Franz
Franz
Re: Perhaps the datasheet tell us more?
What does this "fix"? The data sheet says it reduces the gain at high frequencies. I presume this rolls the amp off well above 20kHz. I can *hear* this noise. It's probably 5-10kHz.
Franz G said:The solution for this problem is a simple 220pF capacitor between the + and - input pin.
Just read it!
Don't stop! Read the next sentence in the datasheet:
"The capacitor also suppresses external electromagnetic switching noise created from fluorescent lamps."
Just try it 🙂
Franz
Just try it 🙂
Franz
Re: Just read it!
I'll try it, but even should it work I'll still want to know why. I'm fairly skeptical that it would have any effect on junk coupled in from the mains. My pops are mains related: AC supply = pops; battery supply = no pops.
Franz G said:"The capacitor also suppresses external electromagnetic switching noise created from fluorescent lamps."
I have actually two "gainclones", one tube driven (unity gain LM3875) and the other with a tube buffer.
The first one is absolutely not sensitive for this kind of distortion, the second one needed the 220pF cap. The roll of must be much higher than 20kHz, as I can not measure any difference in bandwith of this amp.
Please don't ask me, what are the basics of the engineers, who wrote the datasheet!
I think this sensitivity is not dependent on the buffer, much more on the layout of the PCB and things like that.
I did not try my amps with battery supply 🙂
Franz
Franz
hello guys
i have had the same problem with my NAD 3100 amplifier, it puts out 70watt rms per channel, so a plop on the speakers really makes you go through the roof, i had it when i put on my halogen-lamp; there is a transformer in it and so it gives a lot of spikes when turned off.
the cheapest thing you can do is to put a few VDR; voltage differential resistors (i don't know if this is a good translation) over the mains in the amp. It conducts better with higher voltage, so if there comes a spike it is absorbed by them; i have put 3 of those in my amp, and the plops are completely gone
one of those can bear
peak AC : 420
peak DC : 620
peak current: 4500A (no this is not a mistake)
and it cost 0.5 dollar,
i know it isn't the most audiophile solution, but cheap and it works good. so...
peak AC : 420
peak DC : 620
- Chip Amps
- My Gaiclone "Pops" :(
