Finally, I´m starting GB for printed circuit board for following products:
- PASS F6 PSU - DIY-NR002
10 boards: 176x168x2mm; HAL; 70µm; SILK TOP/BOT; GRN/WHITE
(ordered: @2 PicoDumbs)
- PASS M2 - DIY-NR003
20 boards: 110x120x2mm; HAL; 70µm; SILK TOP; GRN/WHITE
(ordered 1 pair: @MASantos, @wrath; @brianco;@kweeSong lim; @Cambe; @mk57; @vvs57)
- PASS F6 NITROUS - DIY-NR004
20 boards: 110x103x2mm; HAL; 70µm; SILK TOP; GRN/WHITE
(ordered 1pair: @2 PicoDumbs)
- PASS ACA - DIY-NR005
10 boards: 100x80,5x2mm; HAL; 70µm; SILK TOP; GRN/WHITE
- XRK-BF862 HPA (with charger) - DIY-NR006
10 boards: 102x72x1.6mm; ENIG; 35µm; GRN/WHITE
Actually price without postage for this quantities from 14€ and 30€ for F6 SUPPLY.
Following product finished this weekend:
- SUDSEPP - DIY-NR007
Following products before end of next week:
- ZM IRON-PRE (both versions and batteries supply) - DIY-NR008
- JUMA-BF862-PREAMP+CUBIE3 (one big board with LDR volume control) - DIY-NR009
In the line:
- all BOM´s
Would be nice to close first GB end of next week.
JP
In the line:
- all BOM´s
JP
PASS F6-PSU - DIY-NR002
JP
JP
JUMA´s CUBIE3.
JP
JP
Does anybody knows what are the postage costs for international UPS standard shipping from Germany?
I´ll order 30 boards for each project, so I´ll offer:
- DIY-NR002 for 18EUR
- DIY-NR003 for 15EUR
- DIY-NR004 for 14EUR
- DIY-NR005 for 12EUR
- DIY-NR006 for 10EUR
- DIY-NR007 for 9EUR
- without postage costs
Finishing JUMA CUBIE3 power supply.
JP
JP
ups will probably be very expensive and German postal services might offer a cheaper and also reliable option.
can you please confirm the mountain hole distances for the m2 and power supply boards?
M2 amp is UMS mounting compatible, from PCB origin:
- 15; 40
- 15; 80
- 95; 40
- 95; 80
F6 supply, the holes are, from PCB origin:
- 4; 4
- 4; 164
- 91; 4
- 91; 164
- 172; 4
- 172; 164
JP
- 15; 40
- 15; 80
- 95; 40
- 95; 80
- 4; 4
- 4; 164
- 91; 4
- 91; 164
- 172; 4
- 172; 164
JP
In the line:
- all BOM´s
JP
Please remove my name (shown in red) I thought for some reason that this was a M2 POWER SUPPLY board. Apologies.
Done very little due to medical problems! Low BP = fainting! Reduced my beta blockers so now better - at last. But salmon fishing takes precedence over everything else!
If you want to keep prices down China PCB Prototype & Fabrication Manufacturer - PCB Prototype the Easy Way is very cheap.
Especially if the pcb's are less than 10cm by 10cm.
They are also very quick and good quality.
Hallo JP,
I am interested in the M2 boards (DIY-NR003).
Is the price quoted (EUR 15) per board or per pair of boards ?
Best regards,
Claas
Best regards,
Claas
Nice stuff, but once you catch your breath, how about a nice cap multiplier suitable for these amps?
- Group Buys
- My first GB
