Well after hearing so many good reports I thought I would try a set of the CSS FR125s. I normally listen to a set of JBL4412a, with which I have a love hate relationship. They are really loud, and some cds sound great on them. But mostly they sound hard, shouty and boxy, the tweeters are pretty awful.
I made a couple of 7l BR boxes for the fr125s, rear ported. I calculated the vents in WINISD around 50hz, but they turned out much lower, around 35hz. They will eventually be aperiodic or sealed, running with subs.
I have chemical sensitivities, so I am not allowed to work with mdf or plywood. Thus the cabinets are reclaimed hardwood. I haven't made boxes for 10 years or so, so they are a little rough. Cutting it all with a handsaw didn't help the squareness either. I've now learned that hardwood is terrible for speaker cabinets, it really sings! Looks nice though...
How do they sound? I think I can live with these, for a while anyway. Vocals sound really nice. They will need some BSC or a notch filter, they are a bit thin sounding on some cds. Might be the 1k hump that Vikash found in his design. (any assistance in this area would be appreciated, I'll be using active circuits) Bass is amazing for a small driver, but only at very low volumes. I'll need to high pass these to make them usable for my normal listening levels.
I like how they disappear, and the top end is really easy on the ear. It means I can listen to cds now that I couldn't stand on the JBLs. They were dictating what kind of cds I was listening too, and that was no good.
I don't like the off axis performance however, they beam really badly, whether that will be a problem in the long run I'm not sure.
They are for certain one hell of a bargain. Getting this kind of sound out of a $220AUD box is quite amazing. (Thanks to Dan at Darcher Audio for supplying the drivers)
Adam
Adam
You call that rough? You've done a very good job I think, especially with a handsaw. You've even rebated the driver.
Sorry I can't help you with the beaming issue, you may want to check out the Mamboni/ENABL thread, a little bit of paint shouldn't hurt the drivers and the theories make sense. It should smooth the rough edges off at least.
You probably know already but you should avoid pine, it has a lot of formaldehyde.
Try putting a cardboard box over them to protect the cones then a thick blanket over the whole lot and give them a good thrashing for a day or so. I thought driver run-in was rubbish until I had a pair of fostex fullrangers.
Nice job Adam,
Nice job Adam,
OzMikeH said:You call that rough? You've done a very good job I think, especially with a handsaw. You've even rebated the driver.
Nice job Adam,
for the break-in period, if you wire out of phase and place the drivers face to face, you can run a lot more "power" through them
Ask Dave D @ planet10 about his experience with cone treatment on the FR/WR125 drivers.
I like it.
Yeah, I'm not surprised about the beaming issue. I'm sure they still sound good though.
I'd love to try a pair of these in an OB with augmentation.
..No extra cash to spend right now tho. 🙁
Nice job!
Nice job!
Thanks guys. I'll hook them up to the pc today and try some eq to see what is making them sound thin. Can't wait to get them working with the subs.
Had a play around with some eq, they just need a bit of BSC from around 600hz, roughly 4db. Time to build some filters.
Hi Adam, surely you jest. They look stunningFoxx510 said:I haven't made boxes for 10 years or so, so they are a little rough....
I did some active filters for the FR125S here: http://www.madaboutsound.com/bravura_fr125S_speaker_design.asp
The values would need tweaking for your cabinet, but it might give you some ideas nonetheless.
Vikash
If those are 'rough' I'd very much like to see what you'd consider to be your 'high quality' handiwork. Lovely job.
Thanks. I just would have liked them to be a bit squarer, and the router got away on me a few times... You will notice I used some of the Mad About Sound speaker fasteners, they are great!
I'll breadboard some filters next week. I'm pretty new to active filter design, I'll have a good look over your bravura filter Vikash. If you have time, it would be great if you could briefly describe what each opamp section does according to its IC tag(ie IC1, IC2). I'll be starting off with a buffer and an adjustable BSC compensation circuit, then later adding a 24db octave linkwitz-riley highpass at around 100hz when the subs are built.
Adam
Adam
IC1A - Input Buffer and DC block
IC2B - 12db Hi pass filter
IC2A - Notch filter (BS filter ~ 1Khz)
IC2B - Notch filter (Peak at ~6.5kHz)
IC3A - Notch filter (Peak at ~12kHz)
IC4A - Peak filter (Dip at ~ 10kHz)
IC3B - Simulated inductor for peak filter
IC4B - Output Buffer
This thread will highlight the design for you: http://www.diyaudio.com/forums/showthread.php?s=&threadid=100525&highlight=
V
V
Thanks a lot for that Vikash, it is much appreciated. I will probably go for a shelving eq for the bsc, I tried a notch around 1k but it still sounded thin. I think 4-5 db from around 600hz will be what I need with these cabinets. I do like a "fuller" sound than some though.
Adam
Adam
Impressive looking speakers Adam. Love the hardwood thats for sure. Was thinking of doing my next speakers in hardwood with the FRs up top plus a pair of Adire Extremis' to take care of the bottom.
Thanks. Be a bit careful with the hardwood, it looks nice, but mine ring really badly and will need more damping. They sound a bit nasaly at the moment, I'll build a measurement mike this week and see what is going on. I hope it's not the box causing the problem, but I think it is.
I did some rough response measurements today. They are very similar to the ones Vikash posted for his Bravura monitors.
That looks like a raw response to me. The Bravura's measure like this:
Your measurments look good. If you apply the transfer function as shown to your measurements, you should get a flat response all the way through
- Full Range
- My first fullrange project - FR125s
