Musical Paradise Amps
Hello folks,
Has anyone sampled either of these amps with a full range speaker?
MP-401 MP-401 MK3 EL34 KT88 Tube Amplifier
with some options:
* Preamp Tubes:
Shuguang 6J8P
KENRAD 6SH7 (+$25.00 USD)
GE/RCA/Sylvania 6SJ7 (+$65.00 USD)
* Power Tubes:
6L6
EL34 (+$5.00 USD)
6L6 + EL34 (+$30.00 USD)
Shuguang KT88 (+$45.00 USD)
Gold Lion KT66 (+$85.00 USD)
Gold Lion KT77 (+$95.00 USD)
or the
MP-301 MP-301 MK3 Mini Tube Amplifier with Headphone Output (2018 Deluxe Version)
With options:
* Power Tubes:
EL34
Shuguang KT88 (+$60.00 USD)
I have heard some pretty good demos over youtube with the 301 YouTube and they sound pretty good.
I am trying to compare these amps with the Audio Nirvana amp which features the following:
Features
EL84 Ultralinear vacuum tube stereo amplifier.
Four EL84 and two 12AX7 vacuum tubes.
Conservatively rated at 10 watts per channel.
Hand wired. No integrated circuits.
Transformers wound in our own factory.
Polished stainless steel chassis.
Brushed aluminum face and back plates.
Two pairs of silver and black knobs included.
4 and 8 ohm gold plated metal speaker terminals.
Accepts two line level inputs.
Voltage selector for 115 or 230 volts.
Excellent build quality will ensure years of reliable service.
$599 with free USA shipping
Specifications
INPUT IMPEDANCE: 100K ohm (RCA)
OUTPUT IMPEDANCE: 4 ohm - 8 ohm
OUTPUT POWER: 10W into 8 ohms, CLASS AB
DAMPING FACTOR: >3
FREQUENCY RESPONSE: 20Hz-20KHz -1dB
T.H.D.: <1% 20Hz-20KHz (REF. OUTPUT)
TOTAL GAIN: 32dB
INPUT SENSITIVITY: 300mV - 600mV
S/N: >90dB (HUM NOISE <1.5mV)
CHANNEL BALANCE: <1dB 20Hz-20KHz (MAX. VOLUME)
CHANNEL SEPARATION: >65dB 20Hz-20KHz
TUBE COMPLEMENT:
Preamp tubes 12AX7 x 2
Power tubes EL84 x 4
POWER REQUIREMENT: AC 230V or 115V ±5%. 50/60Hz
DIMENSIONS: L x W x H 250 mm × 250 mm × 150 mm - 10 x 10 x 6"
WEIGHT: N.W.: 7.5 KGS - 16.5 lbs.
G.W.: 8.8 KGS - 19.5 lbs.
With all this being said, I plan to use thus amp with the Audio Nirvana 8" plus alnico. Now, Dave, the owner of Audio N indicated that this AN amp would be the best amp to go with the AN speaker drivers Im buying, however, I'd like to hear from someone different than the seller.
Thanks in advance.
another chinese amp ...
if you want a good amp for good price,research an Mingda amp .
chinese amp too but ...
-good chassis
-good opts
-P2p assembly
- good composants quality
all of this for reasonable price on market of second hand
If the description of both amps is correct (no feedback), then:
If triode wired it should have a reasonable damping factor
If Ultra Linear wired, it should have some damping.
If it is Pentode wired, it has no damping factor.
You can change the wiring from pentode mode to triode mode.
But if the output transformer does not have Ultra Linear taps, you can not wire for UL.
The second amp mentions a PCB. It is not suited for major modifications.
The first amp does not mention a PCB, might be point to point wiring.
I think you might get what you pay for, you might not.
Who knows the quality of the parts, and such things as the output transformer impedance, quality, etc.
I those are steel chassis, they will be hard to modify.
I prefer aluminum chassis.
You might find a used old classic american amp.
Limited funds gives few options.
Do you want the amp you purchase to always be unmodified?
I've got an Audio Nirvana EL84 amp that I've been running everyday for the past two years, driving AN 8" alnico speaker drivers.
All I can say is that it's the best $500 ($499 when I bought it), I have spent on any stereo gear in a long time.
However, I've never owned one of the other Chinese amps mentioned, so I can't give a comparison.
Compared to my other similar PP EL84 amps, it sounds great. I'm not a trained audio critic and I don't claim to have ears that can hear the difference between different brands of tubes, I do know live music and how it should sound and can say that the AN EL84 amp is a great buy. Among the nine tube amps I own, the AN EL 84 amp and the AN speaker drivers/speakers are my son's favorite system. He has much better ears and is a trained musician/songwriter, so he should know.
I have no affiliation with AN, but I am a happy customer.
