My friend asked me to add pre output. I modded his '95 E10 with OPA2604 as a unity gain amp. The opamp is supplied from the phono section based on NE5532 +\-14,5 V measured. Non-inv inputs are directly connected to volume pot wipers. As it is intended for bedroom auditions, no further testing of E10 will be carried. Posted just for the record.
The opamp is located below the volume poton the picture
OPA2604 buffer
10000uF caps replaced
Have replace el caps in both channels
with
with
- Musical Fidelity Elektra E10 integrated amp
