Bernhard said:Is A120 also pure classA ?
Both have a higher bias than convential class AB biased amplifiers, neither one is fully biased in class A.
The A1 I had runs in pure class-A, as long the current into the speakers isn't more than twice of those value from idle current through the output (noted in the attached schematic).Hi,
I have A1 and could get A120, is it worth ?
Now I have a damaged A120 (front plate overprint) respective A200 ISS4 (PCB overprint)
Unfortunately I haven't schematic. But the 230VAC torodial transformer itself provides 2x 26VAC so the VDC value must be approximately 2x 32V (this value is from A1 2x18V5).
observe also this thread:
http://www.diyaudio.com/forums/solid-state/115284-musical-fidelity-a200.html
You are right in case of low impedance speakers like ribbons e.g.Both have a higher bias than convential class AB biased amplifiers, neither one is fully biased in class A.
